Charger Headlight flasher Question
mifirecop
Junior Member
12
0
West Michigan
Have a 08 Charger and the factory headlight flasher has stopped working. After a quick night-time lookover, I was unable to locate the flasher unit or a fuse location. Any help would be appreciated.
Thanks!
Disconnect the battery for ten to fifteen minutes and then reconnect it should clear it up
Also when you are at the dealer next time, have them flash the computer. There is a technical service bulletin from dodge that will allow this problem to be fixed. In the meantime, pulling fuse #30 for a couple of seconds at the fuse block in the trunk will also reset the computer.
JP15559
