Anyone know if the Cobra T6 lights and the Fusion T6 rotating brackets are compatible? I know they’re discontinued, but I’ve only found the cobra brackets at a couple retailers.
Cobra T6's and the Fusion Surface Mounts are the exact same size. The brackets are interchangeable but require some modification since the T6's wires exit out of the upper or lower side, depending on orientation. The Fusions wires exit straight out the back. If you get the Fusion bracket you will need to create new holes for the wires on the T6's to pass through.
