A while back i picked up this NOS Code 3 500 equiped with a 60 watt #7455 halogen bulb. I had only seen pictures of the 500 before and upon receiving it was impressed with the size and weight of the light. Something i found unique about the light is the bulb holder assembly with the vertical tension brackets that hold the bulb in place. All of the other model 500 lights i had seen before had the wire clip type quick change bulb holders that were associated with the Code 3 sealed beam XLs and later models of the Code 3 SDs.
In conversing with Dan (member dmathieu) he indicated he had not seen this type of bulb holder assembly in the model 500 before and believed this one was likely an early release version of the light.
