MtnMan said:Keep in mind that a loaded MX-7000 with rotators is going to pull about 50 amps. A "wall wart" adapter from Radio Shack isn't going to do it.
stok2 said:I have a computer power supply that is 850watt output. Is it possible to just cutoff the pin connector and splice this into the wires of the light and then just plug into the wall?
Most computer supplies have a +12V output (usually the yellow wire), but it won't provide sufficient amps for all the lights.stok2 said:I have a computer power supply that is 850watt output. Is it possible to just cutoff the pin connector and splice this into the wires of the light and then just plug into the wall?
jdh said:Just a question, what options are you running. I have a MX that has the 4 rotators, lower FF and RF and I-sects. It only pulls around 10 amps with the #97 bulbs I mentioned above. A computer power supply could handle that.
MtnMan said:Most computer supplies have a +12V output (usually the yellow wire), but it won't provide sufficient amps for all the lights.
More info here: http://www.letu.edu/people/joelkoblich/Tech_Tips/PC%20Power%20Supplies/Tips%20on%20Using%20a%20PC%20Power%20Supply%20for%20Projects.pdf
Skip Goulet said:I'd just get a relatively inexpensive "jumper box" at Sears, etc. The box is rechargeable and will provide plenty of power for a short amount of time. Just don't use a battery charger as that can permanently damage the lightbar.
Batterystuff.comI have a Code 3 MX-7000 Lightbar 48" that I want to wire up to be used in my house. I know I'm gonna need some type of transformer, but not sure what type or where I can get it from. Can anyone give me a hand with this? Thanks!
