Code 3 RX2700
jdh
Geneva, FL
Is there a way I can get the LEDs to all steady burn? I have tried to cycle through the flash patterns without luck. I figured it would be similar to Whelen. Nope.
If not, is there a way I can bypass the board and just direct wire the LED's?
Thanks in advance
Doyle257
658
Cheektowaga, NY
Should be able to bypass the board. Just cut wires, and Start over.
jdh
Geneva, FL
I have looked at the wire diagram for the flasher board, and there is no steady burn override. It does have cruise lights. I tried to cycle through the flash patterns but no steady.
iMoses14
50
Lancaster Co, PA
If I remember correctly, that style requires the control board to have a steady burn.
I have the older Prizm modules that you can program each module to a different pattern including steady burn. I'm selling them for $20 each (8 available).
bassslogic
