Does anyone have any thoughts on where I can find a red lens for the code 3 w3 76 ? thank you
B Brian p New Member Jan 6, 2020 3 Ky Jan 6, 2020 #1 Does anyone have any thoughts on where I can find a red lens for the code 3 w3 76 ? thank you
tsquale Lifetime VIP Donor Oct 12, 2010 10,511 Minnesota, USA Jan 6, 2020 #2 That is also known as a mini bar of the Code 3 SD. Searching for a Code 3 SD may aid you in your search
B Brian p New Member Jan 6, 2020 3 Ky Jan 6, 2020 #3 Ok thank you would you happen to know if a twin sonic lens would fit they look really close here is a pic of mine Attachments B678AB2F-6135-4AA0-88CD-C1AD9C894A86.jpeg 123 KB · Views: 5
tsquale Lifetime VIP Donor Oct 12, 2010 10,511 Minnesota, USA Jan 6, 2020 #4 They don't fit perfectly and require modification.
J jdh Member May 21, 2010 1,555 Geneva, FL Jan 7, 2020 #5 The other issue is the code 3 version had a lip on both sides to hold the dome down.
Stampeed Valkyrie Member Jun 18, 2013 3,709 PA Jan 7, 2020 #6 I have Red Code 3 SD lenses.. PM me if interested. Rob
B Brian p New Member Jan 6, 2020 3 Ky Jan 7, 2020 #7 Stampeed Valkyrie said: I have Red Code 3 SD lenses.. PM me if interested. Rob Click to expand... New to the site not sure how to PM you
