Here is an unusual XL 5000 I picked up when I was up in northern Wisconsin. This appears to be a wrecker bar and is optioned with the following:
Stop, Tail, Turn Lights. Lenses made by Petersen MFG
DOT Clearance Lights mounted underneath the bar Grote 9015 Lights
3 Rotators 2 fast 1 slow, Center has an amber filter for the clear lens portion
2 Flasher Lights with 1156 bulbs
2 Work Lights with 795 Halogen bulbs
2 Solid amber Domes
1 Half Amber Half Clear Dome for the Work lights mounted above.
half diamond or V reflectors as well as reflectors on the STT lights. (Should throw a unique pattern.)
A lot of polishing and care will be needed, might have to get a replacement rotator for the center as the Gear on the reflector is pretty bad.
2 Solid amber Domes
