I have several MX7000 bars, is there a way to link them together to make a 6 panel one like the one in the attached picture? I have 3 panel, and 5 currently.
If you really didnt want to aquire a factory bar that length you could join 2 frames via a thick flat piece of metal plate on the bottom. Using the channels for the mounting bolts you could attach the plate with mutiple bolts on each side like a gusset plate. The other option would be find an aluminum welder to join the 2.
