Combination LED HAW Bulb
Phillyrube
Flatistan
Saw a light today, looked like a standard 3157 backup light, installed in a security vehicle at Disney. Was flashing amber, but still had a white backup function.
Anyone know a brand?
Sparky_911
Supporting Donor
May 15, 2013
2,648
Central Illinois
Superbrightleds.com carries a bulb fitting that description. Burns white (think DRL) then goes amber when you hit the turn signal.
What make/model of vehicle?
Phillyrube
Flatistan
I was thinking they would make a good aux brake light, like replacing the backup lights with something like this. Normal op is white, but hooked to brake lights and flashes red. Using a couple Feniex lights on the license plate bracket as aux brake lights.
Skippy
423
Florida, USA
i have seen the ones with white and amber, just shocked disney would bother with changing out the led socket to accept the dual filament bulb instead of just drilling a hole and sticking a vertex in it.
Phillyrube
Flatistan
I didn't get a close look at it. Was sitting in a parking lot flashing, then he put the car in reverse and bright white, no yellow seen until he pulled forward.
Reactions: Skippy
Safetylight5
