Connectors, Shrink tube, Weather proofing
Alec R
50
eLightbars
What type of connectors work best for what application? Whats the best way to weatherproof connections to prevent corrosion?
Discuss!
Please keep it clean and organized, this forum section is heavily moderated to keep information organized. We're going to use content from these discussions to compile a helpful guide for users seeking information about products in this industry.
wilsonbr90
1,427
Corning, New York
Weatherpak or deutch for disconnectable items
Connecting wires is non-insulated connectors with silicone lined heat shrink whether its for interior or not
fleetcomm
717
south of nowhere
We use weather pak for disconnect and soider and heat shrink for other connections.
Alec R
50
eLightbars
Please keep these forums clear of hubub and tomfoolery, there are plenty of active threads and forum sections for that  :cool:
Excellent suggestions so far, I myself solder and shrink tube the majority of my connections
Reactions: Jluke
after trying the gum method...  (strip all the wire and twist it together then add gum to seal and protect) which didn't work I tried the
butt connector  alone method...
then I tried "sealable" butt connectors, and used wire taps to run one wire off another.
I have now graduated to butt connectors, heat shrink and loom where needed
P1808
108
Florida
It depends on where the wire is going to be run and how long i have to work on it for. If it is inside I use but connectors with heat shrink, if it is outside it is soldered with heat shrink and finished off with the proper size loom. And if I  have time I prefer to solder all connections.
When soldering I use the old telegraph tie method before applying the solder, I have never had one of these come apart.
chief1562
5,840
Slaterville/NY
Used to use wire nuts, roof cement, and saran wrap.
Now weather proof connectors. solder, shrink tubing.
Fully insulated connectors even inside installations.
bassslogic
