Support Conversation Limit
irishff
522
SW Missouri
I am trying to create a new message and it states I can only have 25 conversations and I am over my limit. I went to clear my mailbox (200+). I go to select multiples, and try to go to the upper right side to delete all under the "selected" button and the button does nothing. Please tell me I don't have to go into 200+ conversations and delete each one individually.
Minnesota
I did a little searching and was not able to find my answer.
Is there a way I can download all my messages? I like to keep them so I can look at people I have dealt with (buying,selling or just info). After download them then they can all be deleted from the board.
Any insight or suggestions would be appreciated.
Upvote 0
Minnesota
Xenforo, our forum software, doesn’t support exporting user content. I’m sorry.
No problem. I appreciate all that you do here. I was not aware it was a space issue on the board (tony mentioned in another thread that it is a space issue. Like someone new might have no idea the the difference between a FS light and its amazon knockoff, I have no clue about running websites).
I presume "leave conversation" is deleting the conversation correct? Looks like I can do that for a whole page vs each individual message.
Upvote 0
irishff
522
SW Missouri
Can you please clear my inbox. I have tried going through one by one and it is taking way too long to delete my messages. Thank you!
Upvote 0
Jman423
Sep 10, 2010
3,391
United States
I just want to confirm that you're aware that ALL of you messages will be deleted permanently. If you're OK with, I'll get it taken care of.
Upvote 1
koga
23
Budapest, Hungary
Is the message "You do not have permission to view this page or perform this action." somehow related to this? I am unable to send any PMs. I have 9 out of 10 conversations.
I had opened a sepearate thread for this but it was closed saying that it is not a technicial issue and I should PM a staff member. But how can I PM them when I can not send any PMs?!
Upvote 0
Tony P
Moderator
Sep 13, 2015
1,944
Midwest, USA
@koga
You have not created enough content so the spam filters are preventing you from initiating PMs with general members. If you are interested in buying an item or have an item another member wants it is advisable to post on their thread asking them to PM you as it will boost your content count. You are able to receive PMs from members as long as you have your inbox cleared to be under the max PM limit
Upvote 0
koga
23
Budapest, Hungary
@koga
Thanks for the clarification. I have not seen any explanation for this until now. So may I suggest to change the error message to make this clear? Members naturally assume there is a technical issue if there is a function that suddenly stops working.
Upvote 0
Tony P
Moderator
Sep 13, 2015
1,944
Midwest, USA
How do I delete messages?
Two ways:
1. Within the message that you want to remove, select leave conversation.
2. When viewing your message inbox, check the box on the right side for each message you no longer want. A pop up at the bottom of the screen then gives you options. Select leave conversation, then GO
Reactions: Dave F
Upvote 0
Dave F
Moderator
Sep 13, 2015
1,343
Berks County, PA
For mobile, if you go to see all, to the far right there should be a check box. Select the ones you want to delete: on the bottom left theres a drop down menu, select delete. It will ask you if you want to be alerted to future messages or not in regards to the specific PMs (should the other person ever opt to reply again)
Upvote 0
jdh
Geneva, FL
Two ways:
Thank you
Reactions: Tony P
Upvote 0
jdh
Geneva, FL
Thank you
Upvote 0
167
324
Memphis, TN
Two ways:
Only if you minimize the pop-up ads. Terrible.
Upvote 0
ErikH
