Converting Justice WC from CON3 to LIN
WhelenNDealin
575
Ontario, Canada
Have a 50" Justice WC has LIN9 corners and LTR3 centre modules, but the rest are CON3 with two being CON3 with LR11 takedowns. I want to replace the CON3s with linear LEDs. I also wpukd like to replace the front LTR3 modules with takedowns as well.
What type of linear modules do I need to do this and will it cause issues with programming the bar? Will I have to build a new bar on WeCad, export it and reprogram?
Any help would be much appreciated.
got_yogurt
BC, Canada
It won't cause any programing issues changing the CON3's to linears. Changing the LTR3's to takedowns shouldn't cause any problem either although you'll have to change their programing to come on as takedowns if that's what you want
WhelenNDealin
575
Ontario, Canada
Which linear module do I go with? I know that they're LIN6, but is there a specific model.
wilsonbr90
1,427
Corning, New York
you would need to use either justice or responder style lin6 modules which are hard to come by and pricey when you do.
i don't know what kind of benefit your looking to achieve but it may be lackluster compared to the money it will take to get there.
WhelenNDealin
575
Ontario, Canada
It was just a personal preference for linear LEDs, but having looked around a bit for modules, you're spot on; the very few that I found were pricey as all get out. It'd still be fun to do, but for the cost involved, I think that I'll pass.
jaf10596
