Matt Feist
Hello,
I have 2 Federal Signal Twin Sonics that are stamped CTS. I took one apart because when I put power and ground to it, nothing happens. I did discover someone had been in it before and did some wiring hacks to it. So I need to hook them back up but it's a fairly simple bar set up I just am not sure what goes where. I used a test light and basically jumper cables on a battery to make it go. I did touch one wire to a terminal and I got rotators, w lights, and the steady burn, I can't figure out the rear flasher.
Also, I have 2 that are R/R, am looking for a blue dome. Ebay charges too much.
Thanks
Thanks
