CTS1S Restoration (First bona fide Cal-Spec bar!)
CrownVic97
Hazen, ND
Long backstory to this bar here ----->https://elightbars.org/forums/threads/is-it-worth-trying-to-snag-this-or-not-update-i-did-d.83976/
Short backstory: Purchased this CTS1S up in Williston, ND from a nice couple who moved up from Carson City, NV. The husband's godfather was lead inspector for the San Francisco underground municipality for a long while (dates unknown). When the gentleman passed away 5 years ago at 80 (R.I.P), the folks I met on Sunday inherited a lot of items from him. I walked out of there with the lightbar, extra set of lenses, and an extra speaker grill.
I began going into tear-down mode with this and made some rather....interesting....observations when it comes to large city police department maintenance shops and its technicians. You'll see what I mean in the next few photos...o_O
Yep....whoever maintenanced this CTS didn't take time to put the cable UNDER the speaker tray and instead opted to cut a hole in the lense, wrap the un-used wires with electrical tape, drill in the middle of the back of the speaker tray, and go out the middle of the bottom of the lightbar. Guess they were on a tight, tight schedule to fix stuff and get it back on the street :confused:!
Well, I decided not to futz around with the way it's set (character, ya know?), and went to wrapping up the lead wires with Super 88 and re-tuck the ground connection under the Steady-Burn, Rear Amber Flash lead wires to make it more nice at the terminal block.
By the way, this bar came off the assembly line in June of 1979. This dude is only 8 years older than me, LOL :D !
Other than the FUBAR shop modifications, the interior was pretty damn clean for its age.
More to come soon! Next time: Lens restoration....and I got FOUR of 'em to do...:eek:
H20
65
USA / Washington
Awesome, excited to see your progress... I'll be doing the exact same thing before too long.
southpaw
723
South-West
That does look really clean compared to what one normally sees when these things come apart!
CrownVic97
Hazen, ND
I was surprised at that too, Southpaw. Good thing I don't need to mess around with the rotators as they are already perfectly timed ;)
Reactions: southpaw
CrownVic97
Hazen, ND
Thanks, guy! BTW, PM sent :)
Reactions: H20 and southpaw
ex416
1,021
West Central Wisconsin
i seem to recall quite a while ago someone having a short r/b CTS listed for sale on ebay claiming it was from (IIRC) San Diego with the wiring harness coming from the center of the bar, which was suppose to be the verification that it was a San Diego bar. don't recall any pictures posted of the interior of the bar showing how the wiring was routed inside. may have been routed similar to yours and the way they usually wired them.
CrownVic97
Hazen, ND
Thanks so far, folks! I will try to keep this thread updated as the resto progresses along.
Reactions: southpaw and H20
Jun 18, 2013
3,709
PA
Were both sets of domes cut like that?
At least you can hide it..
Reactions: southpaw
jph2
2,122
USA Michigan
Nice find. Interesting how they cut the domes. They probably figured it was easier to cut the dome once than be bothered with properly routing the wiring each time they serviced the bar. Too bad they didn't realize defacing a Twin would be like putting holes in the Mona Lisa to hang on nails in the wall instead of properly mounting the painting.
CrownVic97
Hazen, ND
Yep, both blue domes had that cut in the corner...o_O
You bet it's a good thing it can be hid under the speaker grill!
Yeah, but considering that was the late 1970s and blue domes were in total abundance from Federal Signal, it didn't really matter to them. Nowadays, if somebody even attempted to cut a TwinSonic dome in such a lazy manner, they'd better be ready for the ELB posse to string them up :eek::D!
CrownVic97
Hazen, ND
All righty! So today I took time this afternoon to clean up both spare lenses before moving to the original set. The blue one definitely had more issues though. But, both lenses cleaned up well for the most part. Besides the spare blue being more "war-torn" than the CTS lense, both had crazing from sitting in the California sun when they were in service.
Eh, for display and clarity, they came out good to me :)
Blue lense "war scars." This crack was fixed with Gorilla Super Glue and weight applied to solidify effectively. This is what happens when someone, with ZERO knowledge of how these bars come apart/put back together, is given the task and a flat tip screwdriver to reinstall the speaker grill over the lenses. Lucky the red side didn't do this....but still...:mad:
Oh hey, another cut-out for that lazy wire harness install work :rolleyes:!
Somebody didn't bother to move the gaskets enough so the lens lip didn't jam up against them when tightening the end cap plates....:rolleyes:
Anywho....let the wet sanding commence! Before shots of its previous condition...
After the 2000 grit and soapy water did the grunt work, I then hit the lens with the Plastix and Powerball treatment. I used the CTS1S to show how well the polishing went :D
You can see the repair work on the cracked side.
The CTS red lens's turn! Before wet sanding and polishing.
After the whole rigmarole...
Of course....complimentary video included :)!
H20
65
USA / Washington
Those cleaned up nicely, great video too
CrownVic97
Hazen, ND
No room for a speaker in a bar that short? Would an STS24 or STS100 fit?
I would guess only a round bell speaker would work, Wailer, but I won't be putting one in the lightbar.
Reactions: southpaw
Jun 18, 2013
3,709
PA
TS100 fits no problem...
I have a 12XS that has one in it... I have pictures somewhere.
Reactions: southpaw
Great job on the domes!
The model 12-S is designed for a single TS-100 to fit (snugly!). Don't know if the FUBAR wiring technique would interfere with the speaker installation, though.
Back in the day, on the standard size bars installed with a single speaker, we installed it on the driver side position instead of the middle. That way a second speaker could be added without having to reposition the single speaker.
CrownVic97
Hazen, ND
Great job bringing those domes back to life! Nice to see them on the Twin and the video is a joy to watch. :)
And those are just the spare ones! Still got the original pair to get after yet. Yeah, it makes me happy to see old lenses given a new lease on life :)
Reactions: southpaw
CrownVic97
Hazen, ND
Big Long Picture/Video Post Ahead!!!
Yesterday morning, I got off of ambulance call in Riverdale and wasn't too tired to go back to bed, so I decided to get the original lenses done and get this CTS1S project marked off the list!
Before treatment...
Shortly after I had taken the original domes off the bar, I took the Dremel after that stupid cut-out for the wire harness and made it more presentable and refined. I also put a wire keeper on for extra measure. The refined cut can't be seen unless you really look for it, so that's a plus.
The final result: A darn good-looking CTS1S ready for the lightbar wall :cool:
I guess y'all gotta see this boss in action again, eh :D?
Thanks for staying tuned to this thread and have a great day out there :)!
CrownVic97
Hazen, ND
Thanks everybody! This was a fun project to work on. Once I get my new lenses for my Model 25 AeroDynic, I'll get some updated pictures of my lightbar wall ;).
Reactions: southpaw
southpaw
723
South-West
Before treatment...
View attachment 209635 View attachment 209636 View attachment 209637
Very nostalgic for me personally!! Thanks!!
Reactions: CrownVic97
Wailer
2,290
Canada
I'm not saying you have to put one in, but the STS series speakers (with round bells) were designed for shorter TwinSonic bars. I just wasn't sure if one would fit in a bar that short.
Reactions: southpaw
CrownVic97
Hazen, ND
I knew that ya meant, dude ;).
I was just tacking on more info to answer other folks' questions if was going to or not :D
Reactions: southpaw
CrownVic97
Hazen, ND
Hard to tell, but that looks like the cable is coming from the center of the bar!
That must have been the way they had to wire it up, I guess. Who knows? Maybe mine is from one of those very patrol cars:D!
Very nice to share those photos on this thread, Southpaw!
Reactions: southpaw
southpaw
723
South-West
Indeed I've seen the wires run from the center and from the side so its whatever the shop master wanted.. I was thinking the same who knows one of those could be yours!!
coop359
495
USA Tennessee
Which way do you display it against the wall. I always liked the amber light mixed with red and blue. But the PAR-46 red to the front is cool also. I don't have a CTS but I do have a Aerodynic with a drivers side amber. I displayed it on the wall back side out.
Jun 18, 2013
3,709
PA
I have a R/R CTS that I usually display amber flasher showing.. but I flip it around every once in awhile when I do my cleaning..
This may stop once I get my R/A CTS finalized.
Reactions: southpaw
CrownVic97
Hazen, ND
Sorry for not posting the picture of this bar on display. This is how I have it orientated :)
wp_20171229_009-jpg.209782
Hilux01
