Wanted Diagnostix Indicator Panel
mike2459
120
South Glens Falls,NY
I've got a whelen strobe traffic advisor and I'm using a whelen ups-690 power supply. I'm looking for a Diagnostix Indicator Panel that I can plug into the power supply so I know all the strobes are fireing and what pattern it's using. I've wired it up to a control box and it works great. But I would like that panel.
mike2459
120
Still looking for the cable or led panel, or a complete Diagnostix Indicator.
shues
NW Indiana
I believe the proper Whelen spelling for what you're after is Diagnostix, not Diagnostic. Anyone using the search function with that spelling should now be able to locate this thread.
mike2459
120
I've got a whelen strobe traffic advisor and I'm using a whelen ups-690 power supply. I'm looking for a Diagnostix Indicator Panel that plugs into the power supply and displays the strobes that are firing and what pattern it's using. I've wired it up to a control box and it works great. But I would like that panel. It's whelen part# 01-0267265-00
Still looking for one to buy
StEaLtH2
2,159
New England
Hey Mike, we used to have an apparatus with the indicator panel you are looking for but it only lights to let you know the strobe is firing, the pattern is not replicated, if the strobe is working properly, the indicator is solid red, if the strobe has failed, the light is not lit... Just wanted to clarify for you in case it makes it less appealing for ya...
mike2459
120
The indicator I'm looking for displays the same pattern that the power supply is flashing. That's so I know I didn't hit the wrong switch by mistake. But thanks anyway. They seem hard to come by. The panel would have at least 6 or 8 leds that would flash with each strobe as it fired. I could be wrong and have it backwards. Can you send me a picture of what you've got? There should be a telephone like cable and phone like plug jacks on the end.
airflores
