Different "Mechanical" Whelen tones
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
Here are some sound samples of Whelen "mechanical tones through the "ages".
Modern Alpha is a new Alpha siren with M tone, 295M is a 295 siren with the M tone replacing t3, Alpha12Q is an original 12Q (before the legal trouble) and Executor is an executor (not using the special speaker).
  • ModernAlpha.mp3
    521.4 KB
  • 295M.mp3
    803 KB
  • alpha12q.mp3
    296.2 KB
  • Executor.mp3
    912.8 KB
firebuff17
776
CT
That Executor!!
I love it.
Glad I was in the right spot at the right time to pick one up with the control head. Just trying to figure out if/how I can wire it up without the control head.
Reactions: StEaLtH2
C17LVFD
Harrisburg, PA
That Executor!!
I love it.
I had my Executor wired without a control head.
Can’t remember if they were positive or negative triggers but I did run it through a SS2000 with touchscreen. Pretty sure positive because I had to use additional relays to negatively trigger the Sc1022 triggers when I had that.
Good luck,
Seth
Reactions: firebuff17
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
That Executor!!
I love it.
I can send you pictures of the connections on mine.
firebuff17
776
CT
Managed to work on it a bit today. I *think* I have it figured out.
But I will Gladly accept any info/photos/diagrams you may have. Having more than less will never hurt. I do have the Whelen pdf install sheet already.
ErikH
