Thanks you!Also make sure he's not covered over any sensor by the dash that controls the drls!
Thanks you!Hi
The DRL are mandatory in canada so I would start at looking at the wiring that was install during it's police use. It could be part of a black out module that wasnt plug back .
Bonjour.
les drl sont obligatoire au canada alors je commencerais par regarder les fils qui ont été utilisé lors de sont service dans les forces de l'ordre.Il se peut que la voiture ai été equipé d'un module fantome et qui n,as pas bien été rebranché.
HelloAnd you went to settings on the display and then lights and made sure daytime running lights is not unchecked?? I understand if the light switch is on the off position and you step on the emergency brake it turns them off as well while your sitting.. searching for other ways to turn them off and on...
Thanks you for your replyIt sounds like it may have been deleted in the BCM. Unfortunately, the only way to reprogram it back is to take it to a dealership or find someone with a scanner/programmer with the correct software. The scanner and software will cost around $1000. I ran into the same issue with a couple of Chevy's I had. I wasn't willing to cough up the money and just lived with it. Still wasn't happy about it.
