Dominator 8 Super LINZ6 wont scan through patterns
GranPrix
530
FL
I have a Dominator 8 Plus Series and it only scans between two patterns. I was going through all the patterns when it just stopped on two of them. When i touch the pattern wire for 1 sec it won't change. When i hold it for longer than a second it will change to the other pattern and vis versa. Any ideas??
Some lights will revert to the previous pattern when held longer than a second or two... Just barely tap the wire
GranPrix
530
FL
Already did that, it just cycles back and forth between those two patterns when I tap the wire
With the unit off. Apply power to the white violet wire and power at the same time to do a factory reset if patterns...
See if that helps
sounds like a problem "beyond user level" may have to send it in to get it looked at
