Dominator Parts?
scc1c01
1
Alabama
New to the whole ELS thing, but can you use regular TIR3s as replacement heads on Dominator lightsticks? Having a hard time finding individual parts.
GranPrix
530
FL
Depends on the TIR module, some are passive, some have internal flashers, different connecting plugs...
dominator modules look like this regarding the wiring..
Dave F
Moderator
Sep 13, 2015
1,343
Berks County, PA
if they are two wire you can simply plug and play (may have to hard wire into the harness if it doesnt have the quick connect)
smart heads (4 wire) you would have to set the pattern to steady on, then hardwire your positive and negative into the harness
hope this helps
You can use any of the TIR3 model, just set flasher ones to steady burn
You will need to cut and transfer the plug over to the new module
If you are having trouble finding parts, just message me, we have most parts in stock!
Safetylight5
