Dual avenger
DFD382
224
0
SOUTH CAROLINA
What is the best way to mount this light in a 2004 ford f150 with the headliner mount or visor mount don't want to keep the suction cups want the best look with out flash back...thanks
JMO but i would go with the headliner mount just so you would have a little more secure mount. Again i haven't has much luck with visor mounts you might but again i would go with the headliner one. I hope that helps
I don't know about a 150, but in the SuperDutys I'd go with the headliner mount. Assuming there's enough clearance to put it above the RVM (if that's what you want, and mind you the clearance is really tight in the 08+ SD) that's the way I'd go.
headliner mount works the best but it will have to be mounted to either side of the rvm,at least it did in my 06 f150 when i had that style light
Jackot26
