Jennifer Rose Towing
A while back I picked up a mini Edge 94 MEDGEP. It was a 4 strobe but one was burned out. When replacing the burned out strobe I noticed it had 2 spare strobe wires from the SL6 power supply. I have a couple of spare inboard strobes I would like to hook up if I can to run it as a 6 head.
All I can find is info on retrofitting this power supply into mini Edges but only using 4 heads. The wiring diagram for that shows front and rear hookups while leaving the 3rd harness empty. Can I mix in 2 inboard strobe heads with the 4 corner heads? Could I swap the connections around so the 4 corners would run and the inboards would be the front cutoff?
Any wiring diagram labeling input and output (what cutoff too) connections?
