Fed Sig Platinum SSP3000 Wiring
prty
76
Ny, usa
When wiring the platinum, do you put a fuse/circuit breaker on the POS or NEG? Because the manual contradicts itself. In text it says put and in-line fuse on the NEG, but on the quick connect guide it says put it on the POS.
2. Crimp a ring terminal on the red lead and connect it to the positive (+12V) battery terminal.
3. Crimp a ring terminal on the black lead and connect it through an in-line fuse to the negative (–NEG) battery terminal. The fuse must be of an amperage capacity sufficient to handle the total vehicle electrical loads.
  • 2562417C (3).pdf
ErikH
