Fed Sig SLR Lightbar Programming
Pucky
38
Virgina Beach - VA
Hello..How can i change the Pattern Programming for a Fed Sig SLR Lightbar ?
(not Change the normal Pattern)
I Need other Light Configuration and all Pods in Worklight funktion.
All Pods are clear and have Red,Blue,Amber,White
Pod 1+7 doesn´t work in Worklight or Szene Funktion
gtpts27
579
Virginia
I may be wrong but my understanding is some of that is in the firmware and isn't user changeable (i.e. if it isn't available as part of standard pattern change programming, then it isn't possible). I have a mini Vision SLR and that's the case w it.
Reactions: Pucky
gtpts27
579
Virginia
Thanks for the answer.
Yes, there is a company software that makes it possible.
This will be sent to dealers and repair Services..
If you do find a way to do it that doesn't require sending in to FS, I'd be interested. Don't believe one does but would be nice if it did!
