If the bulbs are 55w, and there are 4 bulbs, that's close to 18 amps. Allow 3 amps for the motor (guessing), you'll be close to 21 amps. You would probably be ok with 12ga, unless you have a run over 6-8 feet. Otherwise, 10ga is recommended for up to around 18 feet. This should give less than 3% voltage drop. The concern is voltage drop, and heating of the wire. If the amp draw is specifically known, there are wire size tables for amp draw vs length you can Google.
