Federal Signal Signalmaster Question
CHIEFOPS
1,533
NYC
I may be wrong but based on the independent endlamps I don't believe those are FedSig patterns, at least not early generation SignalMaster
CrownVic97
Hazen, ND
The person has that SignalMaster hooked up to a SMC5 controller, with light heads 1 and 8 in the AUX output to alternate flash. The other modes can only be done with the SMC5.
Reactions: denko3 and Jman423
bkulibert
111
Mayville, WI
okay, so I hooked up light heads 1&8 to AUX output. I then pressed the AUX button on controller they just come on steady, not alternate flash.
lbs5
2
Poland
Hello everybody. I bought signalmaster SML-KS with 8216106 controller. Unfortunatelly the cables were cutted, so I don't know how to connect this. Do you have any manual of this kit? Or can you help me which colour from lightbar should be connect with port number? From the lightbar are 6 wires: brown and red - fat wires (+-) and thin : green, yellow, white and black. I have manual for SML-KS-LED, but there no yellow wire :-( Regards from Poland.....
(22012020) Solved :) thx
ErikH
