Feniex 4200DL Re-Install Help
melt
62
Oconomowoc, WI
I am reinstalling my 4200DL controller, relay, and BT module into a new truck. Everything was working perfectly when I removed it from my old truck. After installing everything into the new truck here is what is happening:
  • Relay has power to the red 12v and ground to black.
  • 12v power to the G and H inputs on the relay
  • Green LED on relay is blinking when truck is turned on
  • The controller is able to be programmed by my PC (using the USB cable) without issue
  • When plugging the BT module into the relay using a Cat5e cable, no power light for the BT module, and no power to the controller
  • When plugging the controller into the relay (using a Cat5e cable) without the BT module no power or anything to the controller
Is there anything else I can check for this? Any other thoughts? This was purchased in late 2016/early 2017.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Cat 5 cable most likely went bad
Safetylight5
