Theweda123
Has anyone mounted a feniex fusion 800 light stick to the front windshield?!? If so how did you mount it? Pictures are welcome. Thank you in advance!
This is probably one of those "sounds great on paper" ideas. But it's not what the light was designed for - just get an interior bar, those are designed to fit a lot better than a straight lightstick.
Yes! Finally someone gets what I’ve been saying. Creativity and mods are never done when you own a Wrangler.ordinarily i would agree with you, but the straight glass of a Wrangler rules out most ILBs. as a jeep guy i can attest that you have to get creative for lights with wranglers
For flash back I bought a piece of abs plastic off amazon and cut it to size with a 2" overhang on each side, then used a heat gun to make it wrap the side of the light bar. More trimming to match the window curve, then used a piece of heavy duty 1.5" Velcro from home Depot. Wrapped the edges with sticky foam and have zero flash back. This was mounted to the rear window of a 17 Ford explorerHas anyone mounted a feniex fusion 800 light stick to the front windshield?!? If so how did you mount it? Pictures are welcome. Thank you in advance!
OP didn't say Wrangler. Yeah, obviously ILBs don't fit Wranglers.ordinarily i would agree with you, but the straight glass of a Wrangler rules out most ILBs. as a jeep guy i can attest that you have to get creative for lights with wranglers
