Musicforhim
I originally ordered a cobra visor bar and now trying to upgrade to the fusion. The configuration I want is:
R/W R/W R/W T/D T/D R/W R/W R/W
...all red on the warning with flashing takedown and then to be able to go to a flood mode for the whole bar. Found out you can't have a flood mode with takedown heads...it's either or, not both.
My solution is to order two independent white center heads and use the wigwag feature of a mini-4200 to flash the lights like flashing takedowns. They would be wired to buttons 1 and 2.
But here's my QUESTION: Can I splice the independent white center lights in a way that will allow them to go to the wig-wag wires (buttons 1 and 2) and then combine both light wires to also go to a third button (say button 3) for a steady ON? I'd have to make sure that both the wig-wag function and steady on weren't activated together. Do I endanger burning the mini4200 at all? Can this even work?
Thanks in advance for your help!
