Feniex TyphoonWiring
conkexp
1
U.S
I am having trouble figuring out exactly what i need to do. i have seen threads using the sea blue distribution block, however don’t really understand why those are used and not just a bus at distribution block. i get the extra fuses for each light but is that overkill.
i also wanted to use a fuse tap as my 12v power source. if i just tap a fuse that is ignition powered as my source for the typhoon ( in the attached charge guard) isn’t that sufficient and is the recommended 25a? What is the reasoning behind both constant power and ignition power for the charge guard / typhoon when you can just tie 12v typhoon supply to an ignition source?
please see attached photo for how i am thinking to mount my equipment on a 12x12 piece of plastic. please provide recommendations for best / safest route.
i was also going to purchase the UBL wire that has multiple conductors in the jacketing is this the easiest for running all these wires back to this setup?
Nosajj
