Wanted Flush mount Whelen Edge frame
gtpts27
579
Virginia
Found below pic online (not my pic). Similar to the 4000 series flush mount Advantedge frames but without the lip and not as deep. I know some were used as message boards and perhaps some as TAs.
soutthpaw
135
Sparks, NV
Okay, I thought that is maybe what you meant, I have one but not selling it unfortunately, I did cut a couple of Full bars down to be one sided like this. I have to trim the ends and caps to fit still. they are obviously deeper that the flush mounts. those were on ambulances a lot...
gtpts27
579
Virginia
No, unfortunately, but I appreciate suggestion. Those are 4500's, which are in the Advantedge lineage. I need a flush mount Edge frame, which are much less common.
gtpts27
579
Virginia
Getting closer but that's still an Advantedge frame, just an earlier generation (4000 Advantedfe, other was a 4500, but there was a 5000 that came between the 4k and 4.5k). Blue below is example of what I'm after (though frame too short for my needs). Endcap is a partial Edge endcap, and requires the metal extension piece (which I have). Red is a 4k Advantedge endcap. From photos endcaps are about the only way to tell them apart, though the lenses on an Advantedge are bigger (taller and more trapazoidal) than Edge lenses (which are squared). Hard to gaugethat in a pic though. Because of the Advantedge's popularity for flush mount applications, they are what you usually see in the wild.
6EA39502-A332-42F1-8242-D1770A1E9F5B.jpegFC7624C8-7DC8-4B1E-9CCC-BC0A4C792505.jpeg44AF225D-BB39-45C0-9D76-9A0F9F2925A1.jpeg
airflores
