paff2
I have the fuse block pictured below. I currently have a relay hooked to it for ignition power but would like to have the option to have power to it at times when the ignition is off. There is a place on the other side that I could hook another power wire from a constant hot with a switch. If I power it through a relay will it back feed? Or what would the best way be to hook in a constant power option?
I should add that the connection at the opposite side from my current power source is hot with the rest of the block.
Thanks
Thanks
