I recently acquired a Grimes model 40-0101-14-12 rotating light. It has a nice glass dome and retention ring (not shown) but is missing it’s bulb. It says to use a 1940 lamp. I can probably find one but was curious if another more common bulb found in light bars would work. As I dug further I discovered the motor appears to be missing. Not being familiar with these lights, I can’t tell if anything else is missing. Does anyone know where I might look for a replacement motor. It wouldn’t need to be original as long as it was something that made the housing rotate. The label reads 14 volt DC. Would a 12 volt battery run it? Thanks in advance for any help.
