Where should I ground my emergency equipment. Why should I ground it at that specific spot?
Should I ground them to the body at each lighthead?
Should I run the grounds back to a central point and ground that to the body or frame?
Should I run the grounds back to a central point and ground that to the battery?
Should I only use a factory bolt or a self tapping screw?
