Haven't posted in a while, here is what I am working on
tsquale
Site Minion
Platinum Supporter
Have been doing some buying/selling/trading and figured I should post some updates.
I got this Dual-Comm from member bkulibert. Initial power up, only one rotator was working, and the domes were shot. I already had replacement domes, so that was an easy fix. Reconnected the power wire on the second rotator and installed a new Signal-Stat 537 flasher and it works well enough for a video and to go in to the collection. The grill on it does not have any speaker holes cut out, and it is apparent from the inside that a speaker was never installed. If anyone has leads on a new Signal-Stat Dual Comm label for the front of the bar, let me know!
The pale amber dome appears to be a clear dome that someone either painted or put a cheap film on. It is peeling off, so I may have a salvageable clear dome. Any tips to ease that process would be appreciated, as scraping it will be a pain
OP
OP
tsquale
tsquale
Site Minion
Platinum Supporter
The other projects include adding to this Whelen Delta as well as this working on this Aerodynic. The Delta will be getting front TD, flashers, and an opticom as well as rear arrow.
The Aerodynic currently isn't rotating. It has 3 geared rotators per side, front/rear flashers, and alley lights with the cutout inserts.
OP
OP
tsquale
tsquale
Site Minion
Platinum Supporter
Annnnnnd I opened up the Aerodynic. It isn't rotating because the motor was stolen from it! Not to worry though, it is already sold and will be boxed up tonight going to its new home.
Stampeed Valkyrie
Senior Member
Silver Supporter
I've been waaay to busy lately with other things to work on anything. Might be awhile before I put stuff out again.
As for the peeling dome.. can you just peel it off? Goo-Gone might help.. not sure though as I always ended up wet-sanding when I came across painted domes.
jph2
Senior Member
Nicely done as always! You breathed new life into that Signal Stat even if it still needs some more cleaning. I also love the Delta. :)
OP
OP
tsquale
tsquale
Site Minion
Platinum Supporter
It won't peel like you would imagine a sticker would. I can get a razor under it little by little before that section breaks off due to it being so brittle. I may have to just wet stand to speed the process up
Maxim2Eng
Premium Member
Platinum Supporter
Try using a hair drier (not as hot as a heat gun) to soften the tint. I saw an episode on Motor Trend Network where the mechanic removed old window tinting by spraying it with water and taping a black garbage bag over it and left it in the sun. After an hour, it pealed right off. I wouldn't recommend that for the dome though.
OP
OP
tsquale
tsquale
Site Minion
Platinum Supporter
Well, tried the hair dryer. Didn't budge at all. Began wetsanding by hand with 80grit and that seems to be taking it off, albeit very painstakingly slowly. The amber color itself went away right away, but it is still evident that the film layer itself is there yet. I think with time, patience, and much effort though I will be able to get it removed and back to clear. We will see how well it polishes up.
coop359
Awesome light. Westmont IL FD first box ambulance had that light on the roof of the box with mars bar with twin chrome speakers and s 888 mounted on the roof of the Ford F series Truck.
Online statistics
Members online
9
Guests online
61
Total visitors
70
Forum statistics
Mannaro
Top Bottom
