Sold HAVIS UT-101 Universal Mobile Laptop Mount (Locking)
FTLRadio
4
0
Pasadena, CA
<td>HAVIS UT-101 Universal Laptop Mount. This unit is "new old stock" still wrapped in its original plastic. Locking laptop tray w/original parts. Does not included stand or components for mounting to/in vehicle. This is a discontinued item and is no longer available directly from HAVIS. $150 shipped.
Product Details:
  • Havis universal laptop mount
  • Non-electronic tray adjustable to fit and secure a large variety of laptop models
  • Easy to use and customize to fit your computing needs
  • Two sets of hold-down lugs provided to accommodate a wide range of laptop heights
  • Thin profile maximizes space inside your mobile workplace
  • Integrated mounting points for the addition of power supplies and rugged communication hub
  • Strain relief holes provided to allow for safe and secure connectivity of peripherals
  • Rounded corners and edges are ideal for your safety in accidents and airbag deployment, in addition to daily use and operation of universal laptop mount.
  • Easy to use latch handle makes certain your computer is safe and secure inside your vehicle.
  • Lock and key supplied for peace of mind theft deterrence.
  • Optional screen stiffener part number SS-UT-X
  • The UT-101 will bolt directly to the following motion devices - C-MD-202, C-MD-204, C-MD-102, C-MD-107 and C-MD-109
  • C-ADP-101 is needed for attaching a UT-101 to a C-MKM-101, C-MKM-102, C-UMM-101 or C-DMM-100 Series
  • Configure Your Computing Device
Specifications:
  • Compatible computer sizes: width - 11.472" (29.1 cm) to 14.192" (36.1 cm), depth - 9.250" (23.5 cm) to 11.000" (27.9 cm), height (with short lugs) - 0.665" (1.7 cm) to 1.265" (3.2 cm), height (with tall lugs) - 1.265" (3.2 cm) to 1.865" (4.7 cm)
  • Four (4) hole mounting hole pattern with 1/4-20 threads, 2.125" x 2.125" (54 mm x 54 mm) center to center
  • Testing & certifications: RoHS, crash tested up to 30 mph
  • Dimensions: 13.2" (33.5 cm) x 11.2" (28.4 cm) x 2.5" (6.3 cm)
  • Product weight: 4.3 lbs. (2.0 kg)
  • Gross Weight: 4.30 lbs
Please email with any questions prior to bidding/purchasing. Shipping to confirmed US addresses only.
Thanks for looking!td>
Sfelock
