Headlight flasher
Bizkitjmd1
CT in good old US of A
Installing a Whelen UHF2150A flasher into a 2005 Chevy Silverado. Are the headlights pos or neg and what color is the trigger wire at the bulbs?
Thanks
James
Positive Switched and High Beam wire is Lt. Green/ Black
here is the info from Sound Off's Compatibility Chart
GM Silverado 1500 Any Positive Switched System Lt Green / Black
ETHFSS-SP
ETHF00-SP
Comments DRL flasher optional (ETHFSS-SP-CMP) = DRL wire Lt Green / Black, located in underhood fuse block connector #1 pin E3
As EVS stated, POS switched system.
For the UHF2150A you ned the Light Green/Black stripe on the right side, and the Light Green/White stripe on the left side.
Just finished doing several suburbans so it is fresh in my head for now. Holler if you have any questions.
VKInert
