Headlight Problem
C420sailor
502
Virginia, USA
Hi! I installed a Whelen UHFPOS HLF in my 98 Explorer a few months back. It has worked flawlessly until recently. I've been having some odd high beam symptoms...
-Both low beams function fine.
-With the HLF off, my left high beam illuminates and my right doesn't.
-With the HLF on, my right high beam flashes and my left doesn't illuminate.
I'm so confused. I've tried tracing the wiring along with the installation instructions/wiring diagram. Has anyone seen this before? Any ideas? Thanks!
C420sailor
502
Virginia, USA
I went through the wiring again and discovered a corroded crimp connector running from the flasher to the drivers (left) side high beam. I removed the crimp connector and soldered the connection and voila! Works perfectly again. Thanks for the suggestions though! :)
Brady Krajeski
