help choosing a mobile scanner antenna
Steve0625
1,213
Northville NY
seankretzer said:
i am wondering what would be the best nmo mount scanner antenna to buy?
I will be scanning
33.020-46.420
120.30-154.28
452.7125-468.050
Unless you live some where that has marginal reception, start with a standard VHF 1/4 wave and see how it goes. They're inexpensive and readily available. In many (I think "most") cases, it should be all you need.
I have a handful of black ones and several SS ones if you're interested.
CHIEFOPS
1,533
NYC
I recommend the Comtelco tri-band antenna, it's not designed for low band but it receives 40mhz very well and around airports I've had decent results on the air band
this one from the shack works well.
I have one on my f 150 and used one on my car for years until I went with a trunk lip nmo mount version of it.
receives all the freqs you have listed well. only THP and electric companys use low band around here.
Ben E.
Iowa, USA
These are the best scanner antennas I've ever used. I wish they made them in permanent mount, because I had to stop using them when I started drilling holes.
Ben.
Scanner master had a version similar to it that was 3/8th 24 thread mount. I bought an adapter to nmo and its on my car now. it actually pics up 42.00 MHz better that the shack antennaes did.
Uman18
423
Port Hueneme, CA
I would recommend you start with a nmo VHF 1/4 wave antenna and go from there, I have ran a 1/4 wave antenna for years (10+ years) and does good on low-band, VHF and UHF. usually these are free if you ask around!
If you feel it doesn't work, then try one of the other scanner antennas.
rwo978
ND, USA
Ditto. Plus, it looks a ton better than most scanner antennas.
CHIEFOPS
1,533
NYC
Comtelco tri-bands, I've used the Z model because of the t-band coverage. That model receives 46mhz very well too and I've monitored the air band while driving in vicinity of airports.
Tri Band Unity Gain VHF, UHF, 800MHz, Bright finish
A11331A-X 144-160 / 435-460 / 885-970MHz
A11331A-Y 150-165 / 450-470 / 806-940MHz
A11331A-Z 150-174 / 450-475 / 825-896MHz
Tri Band Unity Gain VHF, UHF, 800MHz Black finish
A11331B-X 144-160 / 435-460 / 885-970MHz
A11331B-Y 150-165 / 450-470 / 806-940MHz
A11331B-Z 150-174 / 450-475 / 825-896MHz
seankretzer
27
Mid-Atlantic
i tried a 1/4 wave antenna that is on my work truck and had very bad results. I hooked the scanner up to a Motorola HAE4011A uhf antenna and it works great on all bands.
Skip Goulet
4,241
Midland, TX
I used this antenna myself for many years, but they're a bit expensive. The only problem I've experienced with them is if you drive at highway speeds very much, the motion will wear out the part where the antenna screws into the base. But for reception, they're awesome.
A few years ago RS marketed a mobile magnetic scanner antenna that looks like a cell phone antenna. I got one off Ebay for about $15 back when they were available and still use it. It has fantastic range. I drove from Midland to San Angelo a few years ago, before everyone went digital. I had an RS triple-tracker scanner in the car. From Midland to San Angelo is about 115 mi., and I could hear Odessa's then-still-analog trunk going into San Angelo, and Odessa is 20 mi. west of Midland. Not bad! I now use the antenna inside on my Pro2096 digital scanner and it works well, even inside a mobile home!
mikenucc
7
Long Island, New York
I love this antenna. I was getting the cheapest thing so I didn't have high hopes but it definitely outperformed most. $22 at my local RS at the time around 3 years ago. Very easy to maintain and fix if needed. The only problem I've had with it was the coax's braided ground tore away from the base of the antenna over the duration of around 2 years. I soldered it up and works perfect with no report to this day. I started to not like the typical silver antenna due to my ham antennas being all black. So I unscrewed the 2 halves and used black shrink tubing. I love it.
aidey1234
