Help: Installing grill lights in a Silverado with active shutters?
treycash
84
Maury, NC
Has anyone installed grill lights in a newer Silverado/Sierra with the active shutters in the grill? If so how? What kind of lights? Do you have any pictures?
I want to install some in my 2017 Silverado but after reading about the shutters in the grill I am nervous about installing anything in the grill with them.
Sparky_911
Supporting Donor
May 15, 2013
2,648
Central Illinois
I did a grille install on a 16 Ram with AGS and had no problems. The actual grille was separate with about 6 inches of clearance between it and AGS. I did 4 Feniex T6 (fusion) size heads. My '17 Sierra 2500HD doesnt have AGS.
Thread of Ram here:
treycash
84
Maury, NC
Thread of Ram here:
Thanks! Did you attach the lights to the grille? How? In the past, I have installed the grille lights to the radiator brackets.
Sparky_911
Supporting Donor
May 15, 2013
2,648
Central Illinois
I used stainless steel toggle bolts and sandwiched them in. You can accomplish the same thing with fender washers, bolts, and nuts with nylok inserts. Rock solid amd never moved. Plus no drilling holes for cleaner removal.
treycash
84
Maury, NC
Do you have a pic of this method? I am very interested.
Vt_BTFD
7
Barre, Vermont
Closer pics from today. This has been like this for over a year, no issues
Reactions: wojf72
Hilux01
