Help needed for Jet/Vista strobe heads
Pete L.
Virginia (south/central)
Does anyone know what the config. is for the plug on the Jetstrobe and Vista strobe lightheads ?
I mean the red, white and black wires. I know that Whelen uses red for anode, black for cathode and
white for trigger.
Did Federal Signal use the same system ?
Has anyone tried using a Whelen power supply with the Jet/Vista heads ?
MtnMan
1,533
Eastern PA
The color coding is standard; Federal just used a different pin order for their reasons. Any power supply will be fine.
Pete L.
So as long as I match up the colors, I should be OK ??
I was going to use some Whelen CSP690 power supplies on these - 15 watts per head.
Do you know if the Jet/Vista strobes will handle that ??
Federal Signal strobe power supplies never really held up.
ErikH
