Help Needed - Twinsonic Motor, gears and chains
Chri$
31
Bremen, Germany
Hello everyone,
I decided to remove the motor from my twinsonic to clean it, after trying to install it again I noticed I couldn't put the chains back on the gears because they got to short.
Does Anybody know how to fix this problem, I almost tried everything but nothing did fix my problem yet.
Greetings
Chri$
Minnesota
Put the chains on the motor. Then put them on each light before screwing the base to the bar. you will have a bunch of slack to work with to get them back on that way.
SWI712
63
Omaha, NE
That's correct. The base of the rotating lights has slots for the adjustment of chain slack. Be careful not to make the chains too tight.
airflores
