militarymedic23
Would anybody be able to comment on possible causes for FM radio interference when the siren unit is on (not activated for tones, just powered on)?
I'm guessing with the more recent models of Whelen's siren units, the Cantrol, Cencom, newer 295 and the HHS are probably all designed/created around a similar circuitry, so the question would probably apply to any of these products.
I never noticed the FM interference when using an older 295HFS unit and separate lighting switchbox, but today I was able to determine that the 2200 unit just being powered on was generated very random sessions of FM radio interference. Turning off the unit made the radio audio crystal clear, turn it back on and there is a noticeable
difference.
The current installation has power for the unit coming right off the battery, through a fuses distribution box and grounded on the same metal frame point as the battery.
The interference seems somewhat minor at times, but randomly will generate enough interference it's like trying to listen to a station at the very fringe of the broadcast area, a lot of static.
If anybody can spell out suggestions/words of wisdom on techniques that may help address this...
Thank you
difference.
Thank you
