Yes it has the lot apart from arrow stickIt depends on the number of built-in options! Does your MX have only 2 rotators or is it fully equipped with at least 5 rotators and various flasher and Work-/TakeDown-/Alley-lights?
Many thanksHere is the table out of the Code3 MX manual
Add up the specified currents according to the installed lights. And then add a reserve to the calculated amperage (incandescent lamps require much more power when switched on than later in operation).
