Hi-speed rotator motors
soutthpaw
135
Sparks, NV
Anyone happen to know the RPM on the Hi-speed center rotator motors that were used in the old Code 3 lightbars? Anyone have a source to buy these motors at a reasonable price? I am guessing they are double the standard, as the flash rate was double, but I don't know the spec on the RPM of those motors either
soutthpaw
135
Sparks, NV
IIRC the gear head determined the speed not the motor. I think the high speed gear was/is black.
Thanks, you are absolutely correct, I just swapped the black for the white motor gear and it produces a hi-speed rotation. So what is the speed of the motors? Should be around 5000-6000 RPM
Safetylight5
