hideaway question x 2
Frooom
852
NH
Anyone here use AWL Bursts? I notice the dual head kits are on sale for 50 bucks, beats out anyone else by literally 50 bucks for 2.
Second Q, anyone use hella heroes yet? considering them, but not sure they would work for a Nissan, but I like the idea of how easy it would be to remove/reuse with adapters for different vehicles. I was wondering how they work with canbus systems or BCM systems that hyperflash led's. Do they trigger with an activation wire to flash mode or something?
fp13-2
359
Harrisburg, PA
I have the Heroes installed in my 2021 PIU and they are great. Bright, easy to install, and I like that they replace the factory bulb, so no drilling needed. I have them on my reverse lights, so no hyper-flash issue. I do have LED turn signals, but I used Forscan to stop the hyperflash. They have one power wire that you apply, so you only get a single mode option. There is a new Flex version of them that just has 4 steady burn wires, and you add your own flasher. Looking back I probably would have rather done that.
Frooom
852
NH
woah, tell me about Forscan? I really like the idea of the nonflex, that's all I want is one mode to do whatever I set it for, and replace OEM bulbs. I think I wanna go this route so there's no drilling, holes, etc, as I want to sell my truck.
rohmers
856
MA
I have used the awl blasts for many years. They are great if you just need flashing. Get ahold of Tom and get those before they are gone.
Frooom
852
NH
How would you rate output compared to surface stars? Thinking of using 2 red 2 white in my grill instead of traditional grill lights. I'm trying to simplify my build significantly
fp13-2
359
Harrisburg, PA
Forscan is software for Fords (and select Mazda, Lincoln) vehicles that lets you reprogram the car and change things. Think an OBDII reader but way more powerful. I don't know if anything like that exists for Nissan though.
Reactions: Frooom
Frooom
852
NH
Gotcha, that's awesome. Yeah I doubt anything does. Nissan uses a BCM for the lights, real PITA for trying to do LEDs in places. I wanna ask Hella if their hero modules avoid hyperblink and bulb out behaviors.
ErikH
