Horn Ring Help
xcharger95x
26
NYC
I own a 17 Explorer Sport.
I’ve been told it’s a ground activated with a green/white wire on the steering column.
I’m looking to use a SS2000 and had a question regarding the horn ring, specifically the relay. The SS2000 has a white(horn) and white/yellow(horn ring) coming from the harness.
30-
85-
86-
87-
87A-
Could someone fill out the above to know what wire needs to go into which part of the relay? Much appreciated.
Once it’s set up. I want to be able to use the OEM. Horn when the horn/siren button is not activated and when it’s activated to use as a man/horn.
Thanks!
