How to save battery while running emergency lighting
Feb 2, 2011
91
wisconsin
Here is a question that ive been wondering about for a little while, i run many emergency lights and 2 sirens (maybe a little overduing it but thats not the point) when running everything i notice sometimes my battery struggles to keep up with everything, so heres the question, is there anything i can install for example a stereo capacitor or something that can help regulate the draw on the battery so that way i wont kill my battery when i run emergency?
Klein
966
Texas
Upgrade your alternator and battery. I had a Yellow Top Optima and stepped up the alternator when the factory one died. I had dual sirens, 4 speakers, 4 HAW strobes, Fed Sig ILS, SOS Ultralite 8, 2 FS dual vipers, 2 SOS Intersectors, 2 FS Impaxx, 1 SOS Ultralite 4, HLF, 4 Whelen Vertex, 1 UHF radio, flash light charger and other devices on before the upgrade.
Or just cut down on your equipment but what fun is that?
Feb 2, 2011
91
wisconsin
Ya cutting down is no fun! What did you upgrade your alternator too? And how much did you get an optima battery for?
Feb 2, 2011
91
wisconsin
i do have a spot for a second battery in my truck how do you connect them both? need anything special or just some heavy gauge wires running from one to the other?
MEVS06 said:
A yellow top is around $200-225ish. I run dual batteries.
CenTexPSE
Covington, TX
Yes sir. Just connect the two with battery cable. 2-4awg should be fine. Positive to positive, negative to negative.
EVModules
864
Deer Park, WA
2, 3, or 10 batteries is not going to matter unless you adjust the electrical system where the alternator is significantly putting out more than you're drawing out. Either upgrade or reduce the electrical load or you'll find yourself with dead batteries.
Feb 2, 2011
91
wisconsin
i am going to upgrade the alternator right now i have one that puts out 100 amps i think ill go with the 140 amp one and also another battery
nerdly_dood
2,312
Georgia
I generally don't much like LEDs, but if you're worried about your car's electrical system, don't use anything else. LEDs are by far the best type of warning light in low current draw.
Klein
966
Texas
I paid $190 for mine from Adv Auto. I upgraded the alternator to a 200 amp. It also helps to step down your warning once on scene. Use only what you need. EVModules is right. Battery count doesn't matter. Alternators are cheap and easy to do, for the most part. I would either run two regular batteries or just upgrade to a YT Optima but the latter makes more sense to me.
EVModules
864
Deer Park, WA
If you want to do a dual battery setup, it's recommended that you isolate the battery so you can preserve your primary to get you going. The upside-down "T" at the right is a momentary on button if you'd like the extra insurance in getting your vehicle started in case your primary battery isn't sufficient to start your vehicle.
May 27, 2010
155
Lebanon PA
This is where having your lighting on seperate swicthes realy pays off. I like to have my switches set up for front, back, Primary and secondary. Response gets everything but parking seldom needs everything. When I park turn of the end you don't need, turn the headlights off, turn siren off. You get the idea. I have been running 2 model 14's, 2 FS TCL-DM's a Traffic Arrow and some old lolli pop flashers. Running 10-33 is not a problem and when parked turning off the unneeded lights I have never had a problem. I run 1 battery on a 1985 Ford F 250. Dont forget to make sure you got nice clean protected electrical conection from battery to light is an often overlooked issue, check them out once in a while. Same with grounds.
Tommy_adams
