Had a Lacrosse I never did anything with, never thought I would have it long and didn't. So it has been two years since I was lit up.
I now have a Fusion Titanium but it is leased for three years and in Michigan we have that whole lightbar & siren requirement.
Is it do able? With a siren?
Thanks!
Yes, you can so a basic lighting setup without permanent holes, ie:
FRONT
--M4 solid red grill lights ("sandwich-mounted" in front of the grill with a small piece of aluminum & washers behind the grill)
HLF
--Dual red avenger or viper dash light
REAR:
TLF
--Vipers or Avengers on both sides of the rear deck
OTHER:
--Whelen L32 red beacon with suction/mag to have 360
--nForce, impaxx, or linz6 on rear side doors (on L-brackets with double sided 3M tape)
--10-75 intersection bracket with your choice of lighthead
Whelen SA135 speaker (you will have to draw 2 holes to mount the speaker, but it's not like the tech is gonna be looking for traces of a siren bracket when you return it).
Any handheld siren can be used; feed the cables under the rocker & mount the brain under the driver seat so that you can have the remote easily accessible. 3M tape can be used for handhelds like the FedSig 650, which comes with a "cradle"
