emt322636
Hey all just wondering if its possible to "get" an ignition sensor for my CDM1250 so that it'll turn on/off with my key?
emt322636 said:Hey all just wondering if its possible to "get" an ignition sensor for my CDM1250 so that it'll turn on/off with my key?
Oh, I believe it. Many of the EMT's ahead of me in Monroe County back in the early 70's had 000xxx numbers, too.emt322636 said:Thanks, I'll check that out. Believe it or not, I actually used to work and took my paramedic degree program with an old geezer with a 0000xx number. He's still active. I think he's made of adamantium.
SlickTop Solutions said:Just FTI, a 16 pin connector will work as well since pins 1, 10, 11, and 20 aren't used for major items.
If you don't find one here, mre1032 has the 16 and 20 pin plugs plus the 5 ft. ignition wire with AMP connector already crimped on plus other wire versions. He usually has everything listed on Ebay all the time.Zapp Brannigan said:Anyone else have one of these for sale?
andrewsim said:Cable 45 Speaker Ignition Motorola CDM CDM1250 VHF UHF - eBay
Look into this guy, that is the plug I have. He is currently away until June 1st but he has all kinds of configurations available. He uses Motorola factory plugs and Pins and uses the proper crimping tool. Typically will leave you 5' of cable and does a very professional job with very quick delivery.
EDIT: Well... I just noticed what everyone was referring to above (the same guy). This is a link though if it helps
Zapp Brannigan said:Thank you, I am looking into this. Seeing as it has an aux wire for external speaker, if/once plugged in, does it disable the primary speaker on the main/remote head? I would only need this for the ignition sensor, and would not be using an external speaker.
andrewsim said:No sir, the speaker on the head will work even if that wire exists.
