Sarge619
I've recently taken possession of two Federal Signal CJ184's (both in beautiful condition, both with nearly flawless domes, one blue, one red) and wanted to tap the unlimited supply of knowledge from those that frequent this site who know about the details of FS beacons :
The first one I acquired is identified via the front tag as a "SERIAL (series) A1", while the second, newer unit is listed as a "SERIES E2". The A1 version spells out the company name as it was originally known; "Federal Sign and Signal" while the E2 shows the company name as simply "Federal Signal" (I've seen newer series CJ's that sported just the "FS" logo in the past also).
I'm curious what significant differences there were in the various series (i.e. motor types, siren drivers, etc.). I've noticed on my two CJ's that the A1 and E2 chrome plating processes seem slightly different, with the newer E2 being a less brilliant plating process than the older A1.
Also, what was the significant difference between a CJ184 and a CJ284? On one hand I was told it was a different drive system (belt vs. gear - although I've seen pics of what was identified as a CJ284 and it had a belt drive just like my CJ184's) and on the other hand it was the size of the siren driver (58 watt vs. 100 watt). Not sure if any of these explanations were accurate or not. Can someone shed some light (pun intended) on this for me?
Mostly, I'm curious as to the production dates associated with the various series (especially what the last alpha-numeric series number was). As a novice, I'd assume that the A1 would be the first in the series when they debuted in the early 60's? How long were the A1's produced before the next versions replaced them? When would the E2 series have started production? I'm trying to get a better "ball-park" sense of the age of these lights. I know from the seller that the E2 came off a seventies vintage Mack fire truck from Pennsylvania which was upgraded with LED lighting, but have no idea what the A1 was once mounted on, be it police, fire or EMS vehicle.
Once I receive my new gasket this week for the E2 light (the original was pretty well beat and in need of replacement - it's only fault), I'll post pics of these beauties.
Many Thanks in advance for any info!
Mike
Mike
